First time replacing crank shaft in a Honda GCV160 engine
Chris Parman
  • / First time replacing crank shaft in a Honda GCV160 engine
I'm currently replacing the crank shaft (replacing the original bent PTO end of the crank shaft) in a GCV160 which is two years old (mounted to a HRR216K10VKAA model). It's beyond me how anyone could abuse a two year old Honda lawn mower, but I digress. I tore down the engine and waiting on parts. The internal aspect of the engine is that it is very clean inside and no foreign debris found. Being that it is my first try at this (I'm very mechanically incline) and there are seasoned DIY-ers on this forum. How successful has this type of rebuild been for others and what glitches did anyone come across during such repair. Here are some picture of the GCV160 halved. Thank you all who reply.
Hammermechanicman
Consider changing the cam belt while in there.
bogdaN
I am sure you took some pic,s how timing is set.
Russ2251
Honda GCV timing. Set up the following and slide on belt.HONDA OHC TIMING_1.jpgHONDA OHC TIMING_2.jpg
Chris Parman
I'm about 80% complete with my first GCV160 rebuild (replacing a bent crank shaft), just waiting on on two parts (flywheel bolt and PTO drive pulley). Then I will be able to test my skills. I found torque specs for the GCV160 and utilize proper nut & bolt specs throughout the rebuild. Hopefully the engine will start on the first or second pull.
Scrubcadet10
Moderator
Staff member
Looks good!
