287707-0225-01
engine BS 14.5 i
Murrays numbers
4291CX92A
95334-189336
I got this 25 year old Murray 42" Rider 14.5 front engine to use as a tractor only. After finding out the battery was bad I checked the charging system and found it was putting out 16volts about 3/4 throttle. ( Battery was shot too) So I used Google to gather all the documents I could find and I found most of them. Using the IPLs I saw it had a regulator and figured that was problem so I ordered it. I go down to the tractor and I can not find it. Unless its on the front of the tractor I did not have a dry place to get down to look there. I felt it should have been near the starter. These IPLs are seldom clear on position..
It cranks and runs. I hate to cook my new battery. I saw no hanging wires, in fact to be that old, its in good shape and runs great. Its loud enough to remind me of my old MEP016b generator loud enough to wake the dead/
So I also did not find a missing bolt hole where the regulator might have sat. Briggs archive is complete and clear until this came up. Briggs made Murray then.
Can someone tell me where to look? thanks
engine BS 14.5 i
Murrays numbers
4291CX92A
95334-189336
