Finding correct B&S pull start recoil assembly
benmelton0
I cannot find correct pull start recoil Assembly for my 13hp intec engine can anybody help me?
dougand3
Post your engine model #. Eg: 28A707-1234-E1. On a shroud or valve cover.
benmelton0
21A902 0149 E1 I have 2 already that are supposed to be the right ones but the bolt pattern is too small I need the distance to be 8.25 inches diagonally across the bolt holes
dougand3
I see this # in multiple places. What is your date code?
Starter-Rewind
Part Number: 591606
Note: Used After Code Date 12082600
$68.72
benmelton0
That is not the right one either the bolt pattern needs to be 8.25 diagonally across the bolt holes
dougand3
Yours is 2004. Looks like they only made pull starters for 2012 and newer. Maybe another recoil can be adapted.
Heck, for $70 price...I'd figure a way to wrap a rope with pull handle around the FW cup.
Or I'd fix the electric start - 13hp 21ci engine is pretty hefty to be pulling on.
benmelton0
Thank you very much
Appears you are looking PN 695130.
