hello everybody!
I am a newbee here with a problem. i gather that happens a lot. i have lurked on this site many times before joining. i have the app on my iPod for over two years. you all seem to be friendly and reliable.
i have a Craftsman YT3000 with the 21 hp briggs single cylinder. bought it new a little less than 2 yrs ago. installed a fuel cutoff valve right away and shut down by cutting fuel to motor. i did that a couple of days ago and heard gurgling when i went to restart. i always start with choke unless engine is still hot. this time i used choke when probably still warm and the cylinder filled with gas. it would not crank - hydraulic block, i'm guessing. rotated the cylinder and heard fuel drain--into muffler, i hope not crankcase. fuel also came out of air filter. i shut off the fuel and let sit for awhile to evaporate--over a day or two.
just went out to try starting, turn fuel on and heard gurgling--same thing. Have i got something stuck in the carb somewhere--obviously!? anybody had this happen and what's the fix. i have really terrible luck with gas mowers.
thanks and glad to be here
