FH580V spring
gregjo1948
Where does the governor spring attach at the opposite end from the governor arm? thanks, gregjo1948
Scrubcadet10
Moderator
Staff member
does the spring slide over the rod coming from the governor to the carb?
If so,it goes into the hole that the governor rod goes to on the carb.
I assume it's this spring, is long and skinny?
gregjo1948
It's the other spring which is much short and stouter. I figured it out. Thanks for your reply.
