Richie F
- Aug 8, 2019
- 19
- 276
Engine is a 14 hp. on a Scag walk behind mower.
End of season started with no problem and moved into shed.
This season won't start but only pop out the exhaust when trying to do so.
That shows the engine has fuel,spark and compression.
Have checked valves and are in spec.
Pulls over with no problem. Compression release is working correctly.
I thought timing might be off and inspected the key on flywheel and it's fine.
Is there an issue with the coil on this engine ?
Thanks.
Thanks.
