Hair-trigger
- Sep 7, 2014
- 1
- 3
Is there some trick to getting the bronze self propelled gear off the shaft?
Gary
Gary
Well I guess I'll Grind it off ......... ??
Isn't the timing fixed due to where the key is positioned at the factory by machining the slot on the flywheel?I was wondering if you had any measurements of the port heights or widths and timing of the F series lawn boy engine? or if you could take any while it's apart
