- Nov 29, 2014
- 64
- 24,705
gat a head scratcher here that is driving me mad and even worse it is a good customers EZ 225 with a B & S 31P707 engine
SO last year they suffered a leaking float needle which allowed the sump to fill with fuel
So it was a double oil change & Nikki rebuild
For once I did not field test it as I was about to go away for 2 weeks.
Got a call 2 weeks latter that it had died on the grass
Picked it up expecting to find a blown head gasket but it leak down tested fine .
Noticed the fuel filter was empty and knowing that hubby had removed & cleaned out the fuel tank I suspected the fuel pick up tube so pulled the tank to remove the tube but it was fine , removed & checked the carb, it was working fine .
Checked the fuel pump , both check valves seemed to be OK & diaphragm held vacuum & pressure ( when the appropriate tube was blocked ) checked the crankcase breather , no problem there either , pressure tested all fuel lines, no problem there either .
In a fit of defeatism I popped in a new Stens pump & the darn thing fired up then ran fine while I did a 3 hour test drive .
next day checked it would start from cold , it do so it got returned to the customer .
Drove it off the trailer & parked it in her machinery shed
She mowed once , about 2 hours with no problems then the next time it dies after 3 minutes & refused to start
Decided to do an on site, and suspecting the Stens pump, I grabbed another , fitted it & the mower fired right up
A week latter she was back on the phone.
Filter bone dry so I replaced the filter & the Stens pump with a genuine Walbro under warranty
Two weeks latter she is back on the phone , did one full mow , about 3 hours then the next time she got 1/2 way through her 2 acres & it died again.
So before I go back & replace all of the fuel lines & clips any one see some thing I am missing ?
Right now I am out of ideas
