dewguy1999
- Aug 14, 2014
- 9
- 145
External Fuel Filter on a Lawn-Boy Duraforce?
Over the last few days while looking for fuel shut-off valves I've run across forum posts (can't remember if they were here or not) that advocate installing an inline fuel filter between the shut-off valve and the carb. Various types were mentioned. Well, I ran across this in the the "E Engine Service Manual":
So is it necessary to add an inline fuel filter when there's one already built-in to the fuel tank?
The E engine uses a plastic fuel tank with a non-replaceable 75 micron in-tank filter screen. The filter is welded in the bottom of the tank over a sediment reservoir.
