eXmark mower will not start...
spanky
Have an eXmark Lazer Z that doesn't seem to be getting power.
When you turn the key, you can usually hear the fuel solenoid, but I'm no longer hearing that.
Test light shows power at the ignition and also at the starter. All fuses are good.
Would replacing the fuel solenoid fix the problem?
Also, with no power, if I have to take it in to a shop for service, is there a way to 'disengage' the wheels to get it onto a trailer?
The mower was inherited (along with about 12 acres to keep cut), and I'm not too mechanically inclined.
Thanks for any help you can offer!
