exmark metro drive belts
MikeyP04
i acquired a exmark metro 36" mower recently. the 2 drive belts keep coming off the pulleys when i would pull it backwards, this happens with and without the mower running. i thought that the belts were worn so i replaced them only to have the same problem. is there something that im missing? ive adjusted the belts properly. any help would be appreciated THANKS
mechanic mark
Use OEM belts & parts, check pulleys, bearings, etc. by hand making sure everything is tight & secure, no bearing noise when spinning pulleys by hand etc. check parts for wear side to side & up & down by hand.
