Full synthetic 10W30 is easy enough to find, but the Exmark maintenance manual is asking for API rating SF/SG which has the ZDDP zinc additive package to protect camshafts. Most of your common oils these days are rated SL/SN/SM and are designed for cars with catalytic converters. Those oils don't have the zinc additives because they kill the catalytic converters.
You can get regular mineral oil with the correct rating, but it's very hard to find in Full-Synthetic. Where can one find the correct substitute engine oils ?
Apologies if this has been discussed. I did do a search. Thanks in advance.
