Everride warrior 60 zkw2560 deck belt
Joshoooah
For the life of me I can't figure out how to replace the deck belt. The drive belt pulley is over the deck belt pulley on the spindle and it's a bigger pulley that's tight up against the deck. Was wondering if their is a best way to replace. Right now I'm looking at either pulling the pulley or the spindle.
That would be the only mower that has this set up
Every other mower I have worked on, around 5000 or so, the smaller pulley is the transmission & the pulley stack has it on top .
Was this mower bought new or used ?
I can not find a parts breakdown for a zkw2560 , the closest I can find is a ezkw2352
Now the exploded parts diagram is printed upside down , and it shows the drive pulley above the clutch pulley remembering that the top of the image is the bottom of the mower ( note the position of the lap bars )
Joshoooah
Nothing to reference that parts break down against
When you get under the mower and look up do you see the drive belt ?
If so then some brain dead moron has the diagram upside down and some equally brain dead mechanic has installed the clutch & drive pulleys the wrong way round on the PTO shaft.
That is what happens when daddy gives his 5th generation inbreed son a job in the factory because you can draw all of the bits on a computer
For the set up to work as depicted then there would need to be another flat plat e above the belt for the engine to bolt onto and unless the engine is running backwards the tension pulley is on the wrong belt run.
MParr
