Everride warrior 60 zkw2560 deck belt replacement
Joshoooah
  • / Everride warrior 60 zkw2560 deck belt replacement
For the life of me I can't figure out how to change the deck belt with out removing the top pully on the spindle, or removing the spindle itself. Any help is appreciated.
If you removed the tensioner arm and you still can’t get it off, it’s not uncommon on some decks to have to remove the top pulley.
