Changed carb on my Craftsman 6.5 Hp Wheel Trimmer (143.996516) . I also installed new ground wire and gov. link with new extension spring. After multiple adjustments (it was reeving at 4600 RPM at idle and full throttle) I got the RPM down to 3400 at idle by adjusting the Idle Restrictor Screw on the carb.
Here is the problem that I can't get a correct fix on. When I push the Throttle down to shut Trimmer off, it reeves up to 4400 RPM and will not shut down ( I need to pull Plug Wire off Spark Plug to stop.
This is a Tecumseh Lev 120 Specs 361047B
Got me baffled, any help would be much appreciated.
Thanks, Bob
Thanks, Bob
