engine swap
tonymsanchez
I have a formula 13.5 H.P ,Tecumseh overhead rider.Engine model OV358EA,any other engines models i can swap out with,or companies i can contact.Thanks again.
Romore
Pretty much any single cylinder in the 12-15 hp range will bolt on, you only need to match crank shaft diameter and length. The tricky part will be modifying the rider wiring.
