sup guy's and gal's i have a craftsman mower model #31p777/0296e1 and a poulan modle# 219807/0389b1 are these motors interchangeable?
the poulan was dry on oil and now its dead, SHAME ON ME. but the craftsman is a good motor but a bad transmission so i believe. on the craftsman there
is a lever on the back, when pulled out, you can drive it; but when it's pushed in you can push the mower by hand without harming the transmission/rear end.
i moved the craftsman mower today and noticed that as i was pushing it one wheel would roll forward and the other would roll backwards go figure!
also on the craftsman the battery does not charge when driving it, so the craftsman is pulling 100% of the electricity directly off the battery. what could be causing this?
