Suzie
- May 22, 2020
- 3
- 7
I have a Troybilt colt rtz mower Kohler courage 19 engine, my mounting bolts keep coming loose, I tried cleaning all the holes out so the blue lock tight would work, but one of them was loose as I was trying to remove it the bolt broke off up in the hole. How should I go about getting it out.? I have sprayed brake cleaner and wd 40 I can't apply heat I'm afraid it will caught fire. I purchased an extractor drill bit but afraid to use it I don't want to damage the thread which are probably already damaged from the motor vibrating while mowing.. Can someone please advise me how to get them out and what to do to get them to stay in.. Oil is in the holes. It also looks to me like the engine has shifted ? I also have oil leaking out when it sits it looks like it is coming from above the pto clutch. Would that be the oil seal bad.. Does it have 2 ? When I crank the mower before the bolt broke some oil was splashed on the mounting surface and was smoking?
