engine hard to spin without plug
suprfngy
I have a riding mower with a 15 hp Tecumseh engine that is hard to turn over without the spark plug in it . Is it time to rebuild?
Scrubcadet10
Moderator
Staff member
Could also be a weak starter. Check battery voltage at the battery, and voltage at the starter lug.
Check and clean your ground cable to
suprfngy
I was turning it over with my makita 1/2 " drill whichis awesome
suprfngy
it even puts a strain on it though
suprfngy
new battery clean connections but hard to turn with spark plug out
suprfngy
could there be anything else slowing it down
tom3
Belts tight? Pull the belts off the bottom pulleys and see what that does. I crank my Lawn Boy with a Sears drill, teaches that mower a lesson too. Was your motor running ok to start with?
