Thanks so much for your quick response. I appreciate the help and I am not a technician. Can you give me an idea what kill wire you are referring to? Is it the wire going to the microswitch on the right control arm?
The wire that connects to the ignition modules on the engine. But the problem could also be a bare wire some place on the mower that is rubbing when you turn right that is part of the ignition kill circuit.
