BehattedLlama
- Jun 23, 2020
- 1
- 1
Having a problem with a Kohler 20hp. Did an engine swap and put it in a DYT4000 that had a Briggs engine that seized up. Everything is working normally on its own-- it starts and drives fine, and the PTO starts and runs normally when in neutral with the mower deck attached. However, when I shift out of neutral with the PTO engaged, the engine sputters and dies. Thoughts?
