Hello!! I have a question for a go ped scooter I have. When it is given throttle the engine bogs down and dies... I have no idea what is going on and I've already tried everything possible.
Things I have tried: Replaced carberatour, adjusted air/fuel mixture screw, new spark plug, compression test, lots of different oil:gas ratios, new fuel lines, different choke positions. New gas tank lid, higher octane gas....
I have no idea what to even do now.
A more detailed version of what is happening: the scooter runs fine every once in a awhile for like 10 minutes... Then it will sound like the engine is slowing down and start to big and die. Then it becomes hard for it to even start up. What do I do? I am in desperate need of help.
Thanks to anyone that throws out any ideas!!!
