Electric start? help?? TORO 20018 SN 220334426
lacrosse_24
I've got a TORO 20018 SN 220334426 , it has an electric start, I'm assuming the battery is dead? My question is should it still start on just a pull cord? Or will the battery being dead prevent any sort of spark occuring?
I cleaned out the carb, it actually looked in pretty good shape, put fresh gas in, changed the oil, it will pull just fine but it doesnt sound like it's close to starting.
Electric start has nothing to do with engine starting. Pull away. If you are cleaning the carb for the first time in 18 years, I suspect you will need to rebuild the carb with a new float needle and seat. Should have a Tecumseh engine model LEV120 which will use part number 631021B. Here is the procedure I use.
Needle and seat replacement.
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. Next check to make sure that the float does not have any liquid in it. If it does, replace. If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: On the side of some Tecumseh carbs you will find a plastic cover. Under this cover will be an idle jet. Remove it and check to see that the jet is open both horizontally and vertically. You should be able to push the old float needle wire through the vertical opening.
lacrosse_24
So basically, it's just the carb?
If it can into the shop with the symptoms you describe that where I would be starting. After I got it running I would be looking at the electric start problem.
