donniebstumped
- Jun 27, 2016
- 1
- 1
Echo Shred n Vac ES210 - The grommet on the gas tank and the gas lines were falling apart so I replaced them. After this the Blower would start but bog down after about a minute of running at full throttle and stall. I cleaned the carburetor and still had the same problem (bogs down at high throttle). I took apart the exhaust and it was pretty clean but completely cleaned it up, same issue. Finally I bought a brand new carburetor (Zama OEM Carburetor C1UK78) and installed it and now it won’t start. I cleaned and checked the spark plug and when I pull the cord I do get spark. I am at a loss of what could be causing this issue, it won't start. Not even with starter fluid. Any help is much appreciated, thanks.
