ECHO weedeater fuel issue
Snapper101
I have a Echo GT 200R string trimmer that I have put 2 carbs on and runs and Idles fine but when I shut it off I have gas runs out the breather. I put a new carb on because the old carb did the same thing. Any Ideas on what makes it do that?
Snapper101
Ah Ha, I think I,ve found the problem, when I put new fuel lines in the return line is a clear one and very soft compared to the old one which is hard to to age. I must of pinched it inside the grommet which would,nt alow the gas to flow back into the tank. So I re did it started it up and did,nt noticed any gas coming out the breather. I,ll keep my fingers crossed and hope that was the problem.
