Hello Guys
New kid on the block :biggrin:
I purchased my Echo SRM0225 last season. Over the winter I left some of the fuel in the tank with stabilizer in it. Now it's time to cut my grass and it starts but after I press on the throttle it will die. If I leave it on run and won't press the throttle it will run smooth all the time. What might cause that? After work I will go and purchase fuel filter , fuel lines and spark plug to replace all of them. But does my carb need to be rebuild?
Thanks for any help
Thanks for any help
