Hello,
I have an ES-250 that has run great for many years. Last few years have only used Trufuel and I use it year round so it never sits long with old gas.
Went to start it last week and it was giving me a real hard time. Definitely primed, Choke or no choke (it was 95° out), air filter completely off or on like normal, throttle open or closed…wouldn’t start for about 50 pulls. That has never happened before.
Finally puttered and stayed alive, and seemed to run functionally well. However, I noticed a burning smell that really almost smelled like burning plastic, but could have been an oil smell. I then noticed puffs of smoke coming from inside where the engine and muffler are.
I shut it down and it wafted smoke for five minutes or so and then stopped.
I figured after 8 years or so, might need a freshening up. So today I put on:
- new carb
- new prime bulb
- new lines including new fuel filter and bleeder
- new air fil
- new spark plug
Added some fresh TruFuel and was ready for a brand new machine. Except again it wouldn’t start. Finally after 20 or so pulls, it puttered to a start and then ran.
Ran and used it for about 5 minutes and have a few observations, but maybe I’m being skewed by it still not starting well. I swear it is down on power/air flow and also sounds grittier (but to be fair I am almost always using it with earbuds or earplugs in).
Finally, I also smelled some of the burning smell, but not as bad. When I shut it off, there were 3 or 4 wafts of white smoke and then it stopped doing that. Smoke could possible have been from residual leakage that still had to burn off?
I’m just worried that the carb wasn’t the issue and that the compression is shot in the motor somehow and oil/fuel is leaking through to the exhaust? Trying to figure out I’m better off chucking this whole thing in the garbage and sucking up the $250 for a new one vs continuing to use this if it’s not worth it, or even dangerous.
Attaching a video of it running after the refresh. Maybe someone with trained ears can tell something. Also, I realize this isn’t a Bentley motor, but is it odd that, even after it’s warmed up, sometimes 100% throttle runs a less rpm than 95%, or so?
Thanks!
- new carb
- new prime bulb
- new air fil
- new spark plug
Thanks!
Echo ES-250 after new carb
youtube.com
