Echo 225 String Trimmer Head Replacement
Brianbr13
Looking to replace the head on my 225 stringer. Have screwdriver in slot to lock shaft and cannot get heat to budge. Am turning clockwise and have tried everything including screwdriver through string hole for torque which only resulted in broken screwdriver. Any suggestions would be appreciated. Thanks
string trimmers heads undo by turning them the same direction that the head spins
So some are left hand & some are right hand .
If they undid turning the opposite direction to the blade spin then they would scre off during use .
Brianbr13
Cannot get the head to move in either direction. All available information indicates that it should turn clockwise for removal.
They self tighten in use so some times can be quite hard to shift
