DYT4000 (917.273638) 18.5 Intek - Dies When Brake is Disengaged
The Push mower
  • / DYT4000 (917.273638) 18.5 Intek - Dies When Brake is Disengaged
Cranks, starts and idles fine, but as soon as I release the brake the engine dies instantly. I checked seat safety switch which is normally closed-when no rider is on the mower and open when a rider is sitting on the mower. I am looking into the interlock switch now, but not 100% sure on how this one operates. Interlock switch black-to-black is closed (continuity) when brake is applied and the white-to-white acts the same. Should there be continuity between black-to-white at on any of the terminals? I am unable to find continuity at any point for any white-to-black connection when brake is applied or not applied on the interlock switch? If not, maybe I should be looking elsewhere for this electrical problem? Thanks for any help/suggestions in advance.
mechanic mark
The Push mower
Thanks for the reply. I cross-connected the pigtail to the seat switch wires with a test wire and the mower still dies every time when I release the brake pedal.
The Push mower
So it was the spring loaded grey connector. The spring has pushed through on the inside plastic shorting the seat switch connection wires. This circuit should be open with a rider in the seat.
mechanic mark
motoman
motoman
I have that model and once the same problem. My post is somewhere here. I (think) I finally took out the ignition / PTO switches and cleaned the contacts. Problem went away.
