dumb question time
2ball
How high would I need to get my riding lawn mower wheels up so oil does not come out of the oil drain hole when I remove the drain plug?
I want to add a oil drain hose to the oil drain hole so I don't have another Valdez oil spill in my garage when I change the oil.
if I got the "drivers" side wheels up 2 feet would that keep oil from coming out?
Would that cause any issues?
tom3
Not sure what kind of engine is on that mower but leaning it way over can really cause a mess in the motor sometimes. I usually make a chute out of cardboard to channel the oil from the drain pipe to a pan.
Sangalli
Most likely that's high enough. Pull the plug slowly and be ready to put it back in if it does run out. Or just do a fresh oil change while your at it!
The base of the engine needs to be around 30 deg to the horrizontal .
The oil level is just below the sump gasket
2ball
maybe i can siphon some out of the fill hole.
I haven't removed a drain in a couple years now to do oil changes on lawn mowers but of course I have a pneumatic oil change system now. Much less oil spills in the shop now. This got to have oil drain pan for hyrostatic oil change though.
1 Lucky Texan
Maybe
Maybe Fumoto or someone else makes a valve that will work?
