Phillyfella2
- Oct 2, 2018
- 1
- 2
I have a Honda HRR 2169 VKA. I was having a problem trying to pull the mower backwards and read about bushings on the drive shaft being the issue. I pulled each wheel and lubed them first with WD40 and the white silicone grease. The wheels now back up easier but the left one will suddenly lock up going forward. I can “free” the wheel for about 8 yards and it will re-lock. Is this likely the result of inadvertently flipping the 12 tooth pinion gear?
