I have a 36 ZCat w/750 hrs. on it. Idler arm is vibrating all over the place. I replaced the two bearings in the arm (they were bad) but its still vibrating a little. While changing the bearings I noticed that on both ends of where the tensioning spring attaches there is ware (the sleeve on the arm and the bolt on the frame). I'm thinking I should replace those parts and get a new spring also.
Any suggestions or comments would be appreciated !
Thanks
Thanks
