drive belt sprocket and tensioner, spacers, etc diagram
perkinstrades
  • / drive belt sprocket and tensioner, spacers, etc diagram
I have an older poulan Pro 54 inch 25 hp riding mower, when I removed the engine I inadvertantly dropped the bracket with the tensioner/idler pulley and the spacers with it. Can't find a diagram showing position of the spacers etc and the position of the bracket. Anyone have a picture or diagram of that area? Don't know the year of this machine but the bracket is a flat steel one with belt guides . I suppose I will figure out where they go if I fool with the assenbly, but a diagram would make things easier.
Unless you post the full model number of the mower so we can look up the IPL & check then you will be getting guesses at best.
The chances of some one being on this list who has the same mower is about the same as winning the lottery
