I replaced the mower belt on my Craftsman LT3000. Once I got it back together, the drive belt immediately started smoking. I pulled the deck back off and it ran fine. Put the deck back on and it started smoking again. I suspect they mower belt is adding some drag to the pulley that spins them both, but is that enough to make it smoke? The belt seems to be about the right size. What's the solution?
Thanks,
Gregg
Thanks,
Gregg
