Drive belt is rubbing...
NICK G
Can anyone PLEASE help with information as to why the drive belt is rubbing against what seems like a vent for the transmission on a Hustler fastrack 42 mini z model 927350....Put a new drive belt and its still rubbing....Also how much oil is needed in each transmission....Thanks
Each IZT needs up to 79 fluid ounces (2336 ml.) of new 20w50 motor oil. This should put the oil level approximately
1⅞" (48 mm) from the top of the housing. This should be checked at the fill port.
NICK G
Thanks...you're the real M.V.P....??
