DOM for 322L
PTmowerMech
Black tag reads
Husqvarna 322L
967 17 52-01
s/n 17 1501332
Husqvarna AB
Trying to figure out the dates on these, is troublesome. BTW, about 1 inch down (towards the shaft), there's a rectangle hole with a threaded hole in it. What is supposed to be there? Just a set screw of some sort? Or something rectangle?
I'll just post the pic.
tom3
Don't have a clue what I'm looking at but I see something shiny at the bottom. Maybe a lock bolt, tightens up and locks a shaft in place? Lube hole?
PTmowerMech
The view is from the bottom. Almost directly under the sprocket/clutch.
It is a 2017 model. That is as close as I can get the manufacture date.
That is just one the studs that part of the vibration damping system. Nothing to worry about; unless you are replacing the damping rubber
PTmowerMech
2017? I didn't know Husqvarna DOM's were that easy to read. When I was looking up how to find the DOM's, all I could get was fuzzy math.
The year of manufacture is staring you right in the face. Good thing it wasn't a poisonous snake or you be in serious trouble. ON that particular serial number it is the first two digits. Husqvarna also uses the full year on some models (ie 2017).
