Does this mower recharge the battery
Roy405
/model-13a-325-190-yard-bug-1999-/4374-271328
Short answer is YES it should. Take a meter and check battery voltage with the engine running. Should be between 13.6-14.2 VDC. Lower than that and the engines charging system is not working.
Roy405
Thank you. Neighbor gave it to me with a new battery. Tells me that they only last 3-4 years
