DLT 3000 Won't Move
Wolf69
I was mowing and the blades kicked out,I put the blades back in gear with no problem.But the mower would not go forward or backward,like the transmission is out.
You may have broke the transmission drive belt or jammed a stick or something in it and through it off the drive pulleys.
Briana
Hey there! WELCOME to LawnMowerForum! :biggrin:
I moved your thread to the Small Engine & Mower Repair Forum. You'll get a better response there. :thumbsup:
