Dixon Mower Deck
bartles
Anybody know what these "flaps" do...Dixon deck, blade side
bartles
bartles
Further......I have used a product since my youth call "OSPHO" for surface prep in rusty metals. It is basically phosphoric acid. It is a little much to breath in and can sting a bit on exposed skin but it does an awesome job. I just chip and wire brush off all the loose rust, apply with a spray bottle or brush, wait 24 hours, and used it as a primer. I may give your suggestion a go to see if if it is more user friendly.
Any suggestions for a finish coat for the blade side of the deck that is more durable than regulator paint?
Ranchito
I use Rustoleum spray bedliner and it lasts about 12 months. For an annual maintenance, I remove the deck and pressure wash then recoat. Works great here where mowing season is 12 months long.
