busheadfox
- Oct 11, 2021
- 1
- 2
I can't figure it out. Just replaced the sump gasket and bottom seal on Kohler motor from oil leaking problem. Engine runs great now and as long as you are going straight or making left hand turns no problem, but as soon as you try to make a right turn the engine will miss a few times and if you try to make a tight right hand circle around something it will miss so bad than engine will almost cut off and may backfire a time or two. I have jumped out the seat switch and made sure the plug wires were on tight but still misses. It kinda feels like it is being shut off like what would happen if you raised your bottom off of the seat. Any suggestions would be helpful. Seems like its going to be something really simple which is why its so hard to figure out.
Thanks...
Thanks...
