Therapydoc
- Feb 25, 2020
- 1
- 1
Just bought a XT 3300 with a 33 hp Generac motor. Motor makes a winding noise anytime throttle is above 25%. First I figured it would be hydraulics however when I listen closely it’s almost positive coming from the engine. Previous owner said it’s been there over 2 years and never had any issues. Was an older gentlemen so I believe him. There’s no other symptoms. Hydraulics respond well both sides and motor runs strong also and I don’t hear any knocks or anything. He replaced engine oil and hydraulic oil end of last year. He did use Walmart brand 15w40 so I plan to drain and put rotella 15w40 in. He put new spark plugs on it but when I pulled the wires, they are rusty and old so I’m replacing them (any particular wires to use ?). Anything else I should check ? Local mechanic said could possibly be air getting into fuel system but I sprayed carb cleaner along most of the lines and didn’t see anything and motor didn’t bog down any. Worst case scenario, I wear my muffs and live with it but I’d rather fix it if something is wrong.
