Dirty gas tank/ residue inside on bottom
Tedshan
what’s the best way to clean gasoline tank for a Dixie Chopper 2750 without removing it from frame. It has old gas residue in bottom that needs to be removed
Scrubcadet10
Moderator
Staff member
Several gallons of White vinegar. Fill it up.(enough to cover what you're cleaning) let it soak. drain ,repeat as needed.
Tedshan
Thanks, worked like a charm
Truly appreciated
