I have a 3-4 year old Sears Craftsman 21 inch self-propelled mower powered by a 190cc Platinum engine. When mowing on a slope with the carburetor on the low side, it dies. On a flat surface, it runs fine. The obvious answer is that it's starving for fuel. I purchase a new carburetor as a result. It still dies when tilled to the right, so basically no change at all.
The fuel is fresh and tank is full. Oil condition and level is fine. Spark plug is gapped properly and cleaned. I plan on buying a new plug but I don't think that's my problem.
Cracked throttle tube? I even zip-tied the choke arm to the run position to make sure gravity it's pulling it closed on a slope. I'm out of ideas. Thanks for any suggestions.
