PTmowerMech
- Apr 16, 2018
- 391
- 2,998
Dewalt DXPW4240 pressure washer with the 11.6GA13 pump. Runs fine with the trigger pulled. Let go of the trigger and it dies like the unloader is stuck. The 2nd time I started it, (before checking the unloader) it built up so much pressure that it blew the brass fitting for the soap hose So I remove the unloader and it still bogs down and dies?
Now a lot the pressure comes out there. From the looks of it all, 130, 131, 120 and 121 blew out.
Note: I usually only work on the engine side of these. So I don't have a pressure gauge.
But I guess the main question is, if the unloader valve isn't stuck, then how could this build up so much pressure that it bogs the engine down. (Honda GX390)
