Devilbis / Excell Pressure Washer w/ 6HP Briggs Quantum Engine
chuckpen
  • / Devilbis / Excell Pressure Washer w/ 6HP Briggs Quantum Engine
I need to repower a pressure washer with a used engine. My neighbor's 6HP Flat Head Briggs vertical shaft blew a head gasket and ate the piston / cylinder. It has that off center three bolt mounting to the frame.
I believe the shaft is a bit over 3" long and 7/8 diameter with keyway.
I have been considering using a engine from a used lawn mower.
Question: Can I use a mower engine on this pressure washer? Are the shafts the same length and diameter? There are a lot of used mowers out there to purchase. Does anyone have any experience with this swap idea?
I need;
  • 2+ inch shaft
  • 7/8" shaft diameter
  • offset three hole mounting.
  • any other considerations, like differences between a mower and P-washer, like linkages and such.
thanks to all,
/cp
upupandaway
There are many different setups.
post a pic\model numbers so we can tell u.
There are a few different quantums that are used on power washers. Some are the plain briggs. It is like a mower with 1 catch- it has a heavier flywheel than the mower setup.
Some use a Quantum with a stubby shaft, others with a tapered shaft.
chuckpen
Apparently the shaft shrank, it is cold outside though. Looks more like 2 inch now. hope pics help figuring the puzzle.
The specs for the 12H812-2324-D1 is
Crankshaft Specs
Briggs direct replacement is 126L12-1006
Crankshaft Specs
chuckpen
A closing update:
Well, I tried to find a Briggs to fit this need. I did drag home a Briggs mower engine but the shaft was way too long but would work with a different crankshaft I believe. Hope this helps someone in the future. Now looking for a Briggs powered Pressure Washer with a blown pump. hours of fun being had by all.
Crankshaft PTO ends can be shorten as long you have the same keyway width which in your case is 3/16". And as long it upper profile (next the sump cover) is correct.
chuckpen
thanks for the thought. I did consider taking a hack saw (no real machine shop stuff here) to shorten. Not sure if I have enough keyway as the orig engine is 1.8 inches long. I will check it out though. Maybe some spacers and a cut would get me in the ball park. thanks!
