lkjhG1948LMF
- May 18, 2019
- 8
- 14
I believe my tractor is the same as a Simplicity model 4212H hydro
The rear tire is flat and I want to install a tube. It appears that I would have to use a gear puller to remove the rear wheel from the axle. Is it possible to change this 18x9.5-8 tire while the wheel is still mounted on the axle? That is how farm tractor tires are replaced. Please advise
