I have a Z246 with a 46" deck I found a
S skipjobe1 Forum Newbie Joined May 18, 2022 Threads 1 Messages 1 May 18, 2022 / Damaged deck on Z246 with two blades I found a 48" deck with 3 blades will this bolt on? #1 I have a Z246 with a 46" deck I found a
M mechanic mark Lawn Pro Joined Jul 15, 2013 Threads 175 Messages 7,412 May 19, 2022 / Damaged deck on Z246 with two blades I found a 48" deck with 3 blades will this bolt on? #2 If Husqvarna give it a try.
7394 Lawn Addict Joined Sep 5, 2014 Threads 84 Messages 4,717 May 19, 2022 / Damaged deck on Z246 with two blades I found a 48" deck with 3 blades will this bolt on? #3 Belt may need to be changed to accommodate the 3rd spindle pulley. But the 48 should be smoother that the 2 blade 46,
