Dad has a 9 year old 20332. Wheels lock when pulling machine backwards. Installed a new OEM Toro drive belt and adjusted Personal Pace cable clamp. Rear wheels still lock up when pulling backwards. Anyone else have this issue? Mainly the right wheel that locks. Trans pulley turns okay. Trans is probably bone dry inside.
This one doesn't have the half moon key and spring deal on the rear axle ends where the rear wheels bolt on. Dad said the Personal Pace never really worked correctly since new. New OEM Toro belt is awful puny.
I'm either looking at new pulleys, transmission or the Personal Pace transmission return spring. What do you guys think?
