D125 clutch idler pulley not engaging.
gmankiew
Mower not moving in forward or reverse. Transmission rod is working but the clutch idler rod is not engaging the clutch pulley.I see no movement in the clutch rod and can't see where the rod attaches to the forward/reverse peddle even when I turned the whole thing over.
