cv15 not grabbing fuel. gummed up lines but not sure about pump
what should I do?
  • completely remove the whole pump and get a new one
    Votes: 0 0.0%
  • be lazy and do it simple by using a used one
    Votes: 0 0.0%
  • do nothing
    Votes: 0 0.0%
  • Total voters
kd30003
  • / cv15 not grabbing fuel. gummed up lines but not sure about pump
i bought an older 2005 jd lt150 and it ran good until i tried to drain the fuel. after that this thing hasn't seemed to grab any fuel and put it in the carb.
ITS NOT THE CARB!
You may have caused an air trapped pocket in gas line.. I'd suggest removing the exit line & test for gas flow ..
Tiger Small Engine
Take an air compressor blow gun attachment and blow from fuel line to fuel pump back into fuel tank with fuel cap removed. Make sure it is clear and then reattach fuel line to pump. Crank engine and look for strong, steady pulses of fuel out of fuel pump (remove fuel line from pump to carburetor). If all checks out, you know you have fuel getting to carburetor. If it doesn’t start and you have spark, chances are the carburetor needs to be cleaned.
Just note the steel fuel running across the top of the engine can rust closed. So where testing the fuel disconnect the outlet side of the fuel pump and then test the line if the pump is working.
MowerNick
StarTech is probably right. I wont even replace those carbs anymore with out replacing the steel line.
